Corvette C4 How To Videos
I didn't see that one. This is the one I found. http://forums.corvetteforum.com/c4-g...therstrip.html
I just needed to know where the pins were to determine if the door panel needed to be removed. Looks like I can't escape it so I'm replacing the window motors while I'm in there too.
St. Jude Donor '12
That made it look easy to change the under dash CDM but it was not. How do I know because that was my car. Now the charge for that labor was well worth it. 100.00 I took the car over to longwood fl. and had the CDM removed for repair along with 1 speaker amp. Then the next week I went back for the reinstall and to finish the video
I soaked a rag in brake cleaner, ran it along the channel to clean it out. I didn't have to remove the halo lights because when I installed the new side pieces in the hatch, I never installed that last screw, I will go back and insert screws now that I know I won't be taking this apart again. Also, instead of removing both window lift shocks, I removed one at a time. I removed it, slipped the strip underneath and them reinstalled, did the same for both sides. I also started in the corners and worked my way around instead of folding it half to find the center. The whole job took 1/2 hour. No beer.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Hopefully "YouTube" will avoid going public and keep great info like this available to everyone!
Thanks for the link "Mz"
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is the video on the motor gear we did..
Headlamp motor removal and repair.. 88-96
St. Jude Donor '12
Just saw this one posted on You Tube - How to remove the dash-mounted CDM tuner receiver box.
http://www.youtube.com/watch?v=-z7A2OtdRIM
I replaced the rear window weatherstrip about two years ago. Messy job with all the yellow gook under the OEM strip. The new strip was/is so thick, I have to push with both hands to shut the window. No biggie. Thanks for the vids.
#37
video on how to replace 85 inside door panels
Does anyone have any links for a video on how to replace Interior Door panels for my 85 corvette ?...would be greatly appreciated!
thanks Mike
thanks Mike
#38
I have two more videos to add to the list!
How to change plugs and wires on the C4 Lt1
http://www.youtube.com/watch?v=Gr2oFPfAg90
How to gap a spark plug (for our C4 specifically)
http://www.youtube.com/watch?v=IuW3svdqKZM
