Brightest headlights?
I've used the 80/100's now for 3 years with no wiring problems and they throw plenty of light. Any heavier will most likely cause problems with the stock wiring.
Tip on adjusting E code lights.
Set the left/right beam adjustments on high beam. Use low beam for the elevation set.
Agree with Midnight 85. Anything over 100 watts suggest powering with relays .
Both Hella and CIBIE make glass replacement lamp housings to replace the stock 6054 lamp. And they are not so heavy as to cause problems with the headlamp motors or gears as long as they are in decent shape.
The bulb style is H4 and there is a wide variety of bulbs available by wattage or color. Look at the Sylvania SilverStar lamps to start. You can find those at just about any parts store.
The neat thing about the Euro style lamps is that they are designed to keep glare down on the low beam side. The lens pattern gives a flat top to the beam so driving in rain at night is much improved. The pattern also provides additional light towards the shoulder of the road and downwards
80W/100W is the best choice for bulbs; there won't be any problems with excessive load on the wiring or relays.
Thanks for all the advice. Right now I hate driving at night outside the city lighting as the headlights are too dim. And I've always been a fan of late night driving under the stars with the top off. Beautiful way to see the backroads of america.
+1 for Hella E codes.
The Sylvania SilverStars have a relatively short life, and given the pain
to replace a headlight bulb in a C4, I've stayed with the normal
bulb.
Chuck
bulb.
Chuck
Banned Loser
Location: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
I went with the Silverstars from Sylvania, plenty bright enough. I've had mine for 2 years now with no problems at all.
headlights
hi, i have used the hella and the cibie light housings with the hella 55\100 watt and have found that the cibie has the best light beam pattern. i do alot of night driving in my 1995 and have had no headlight gear problems with the extra housing weight. the part number of the cibie is 082462. once in a while you can find these on another site. see ya
Sorry. Couldn't resist.
Reminds me of a story... I was driving across the desert on I-10 in Arizona at about 3:00 AM and the girl who was with me was looking out the window at... dark nothing. I asked her if she was enjoying the scenery.
I've got Silverstars in my car. I would love to have HIDs but I can't justify the cost.
Hi i have upgraded my 100w low 140w high H4 lights to 55w 4300K hi/lo H4 HID type. They are fantastic double the brightness for half the watts .
The conversion kit cost $89. I fitted the Ballasts and relay in the headlight bucket. Just the 12 volt fused supply from the battery and a ground wire to the frame are required all needed was in the kit. (note if you use the neutral from the headlight harness it can keep your lights on due to some back feed so go straight to the frame)
Has been on my vette a few months and i love the extreme white light Just remember to get your headlight aim checked afterwards.
I also use the H4 silverstars but rather than pay for the overpriced hella/cibie I replaced mine with units from autozone that were $30 for the PAIR and have had excellent results.
They also have plastic lenses to keep down the weight so the gel bushings don't stress (I did the 88 upgrade on my 84--much quieter than the 84-87 gears)
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
What is so important or cool about having headlights that blind on coming drivers?
This a generation thing, or ricer imitators?
Just sayin'.
Just sayin'.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Hid
All kidding aside...Properly aimed headlights don't blind drivers. The stock halogen headlights are too yellow and poorly illuminate at distance. Drive a new Audi or similar with HID headlights (they self level so not to blind and flash others) and going back to halogen is akin to driving with just your fog/driving lights on...
BTW, Its kind alike living in Cali and being a gun guy...some things/places are just "better"....no way on God's green earth would I EVER even visit let alone live there....come to a state like PA where you can be FREE! Gun guys especially vette drivers are ALWAYS welcome!
Banned Loser
I really didn't find it much of a pain at all, pretty much the easiest thing i've done to the vette so far.
