Ghost's PKE Module Installation
Old 05-19-2012, 12:50 AM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Default Ghost's PKE Module Installation
First, let me thank Jim(96GS#007) for helping me with the dash trim removal. I tried these
before and I gave up. I ordered the new PKE module from Corvette Recycling over two years
ago and finally it is in and working.
Disconnect the battery
Remove the center console cushion, the center console trim, disconnect the rear window release
button wires, disconnect the lighter. Remove the A/C vents, the fuse box lid, passenger side
under dash skirt.
You have to be gentle with this crap. I call it crap because this must be the cheapest plastic
ever produced, it is brittle and prone to crack on you with barely no effort. I've done this
before and I was extremely careful, but if you take this to the dealer I promise you they will
crack most of the plastic loops or tabs within this project.
Once you loose all dash screws, pull-lift-shake-pull.
View of the seat belt, ignition and warning chime module and PKE module.
Remove the seat belt, ignition and warning chime module. The seat belt, ignition and warning
chime module is velcroed to the PKE module.
The PKE module is directly behind the DIC.
Loose the DIC, carefully pull the wire connection to make room to remove the PKE.
Major PITA
Figure 8, cuss, a brake and finally it came out
Bad left, good right
New is in
The alarm/chime module is in.
Tested the PKE transmiter program before re-installed the dash. Followed owners manual
instructions and all worked great. :seasix:
Old 05-19-2012, 02:33 AM
Mr. Peabody
Support Corvetteforum!
Mr. Peabody's Avatar
C4 of Year Finalist (appearance mods) 2019
Wow, you always do such a great job of showing us step by step how to do each of these projects
Kudos and thank you!!
Old 05-19-2012, 03:52 AM
SQUIRMIN VERMIN 84
SQUIRMIN VERMIN 84's Avatar
Location: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Great write-up and pix, Pete!
Old 05-19-2012, 04:57 AM
GreyGhost
GreyGhost's Avatar
If you don't mind telling how much did it cost? Mine has been on and off working for a while and I have thought of replacing it.
Old 05-19-2012, 08:06 AM
TorchTarga94
TorchTarga94's Avatar
Excellent job Pete, Pics and all!
Old 05-19-2012, 09:58 AM
PLRX
PLRX's Avatar
2017 C4 of Year
I don't remember how much I paid. Contact Corvette Recycling or they also sell it on ebay.
Old 05-19-2012, 12:26 PM
96GS#007
96GS#007's Avatar
Received 1,679 Likes on 1,027 Posts
Nicely done!
Almost everything inside the dash of these cars is a pain to get to / replace.
Old 05-19-2012, 01:21 PM
AaronDoud
AaronDoud's Avatar
Hope i never have to do that but great thread.
Interesting to see you have a corvette logo over the DIC area as well. 2 owners back made a cover just like that for my DIC area. Really makes the car look nice vs the blank area of the DIC normally.
Mine is gold vs white.
Old 05-23-2012, 08:33 AM
Epimax
Epimax's Avatar
Old 05-23-2012, 08:50 AM
Goldcylon
Goldcylon's Avatar
Originally Posted by PLRX
First, let me thank Jim(96GS#007) for helping me with the dash trim removal. I tried these before and I gave up. I ordered the new PKE module from Corvette Recycling over two years ago and finally it is in and working.
I am amazed this worked. The manual lists a pin shorting procedure that has to occur in the harness to the BCM which resets the system to allow you to use a new PKE module. Getting to the PKE module is easy compared to the BCM which is even far lower inside the dash under the radio.
I only mentioned this as I too have been there and done that but after plugging in the new module we had the same problem as the old module. I did not want to probe the BCM in fear of causing other issues so I abandoned this project at that point. I am only sharing this so the rest of the community understands it just may not be this easy (Yeah thats what this was easy)
This was a "new" PKE receiver or a "Doner used" receiver? As to your dash comment it truely is a POS as stated as are the Deluso covered vents etc. Very brittle plastic. That being said Im glad you were able to get everything working again.
Old 05-23-2012, 09:21 AM
Frizlefrak
Frizlefrak's Avatar
Great write up Pete.
Old 05-23-2012, 09:38 AM
PLRX
PLRX's Avatar
2017 C4 of Year
Its from a donor (used). PM sent
Old 05-23-2012, 09:56 AM
Goldcylon
Goldcylon's Avatar
PM answered lol. Im glad this worked for you bro
Old 05-23-2012, 10:08 AM
PLRX
PLRX's Avatar
2017 C4 of Year
Me too, I guess I'm extremely lucky.
Old 06-06-2012, 10:18 AM
pcolt94
pcolt94's Avatar
Somehow this thread got past me.
Nice write up and picture taking. Reminds me when I did mine back in 04, 05 or so before I was in picture taking mode of doing repair work.
I had it apart couple times + as I had checked every input and output wire to it and tried to repair the PKE itself. In the end I got a new box and all worked after that which seems to be the common case.
Old 07-10-2015, 03:05 AM
Decat
Decat's Avatar
Anyway to get the photos working again in this thread?
To Ghost's PKE Module Installation
Quick Reply: Ghost's PKE Module Installation
