22 Years Owning this 86 and this never happened before...
Old 07-09-2012, 12:22 AM
72and86
72and86's Avatar
Default 22 Years Owning this 86 and this never happened before...
I pulled to a gas station to fill up. (I have a 86 vert, 4+3 DN tranny).
I put the shifter in Reverse and turned the car off.
Got the Gas.
Started the car with my foot on the clutch as I should and the Vette wouldn't let the shifter out of reverse to drive forward. As I took my foot off the clutch I kept going backward as I was stuck in reverse!
I gently tried knocking the shift out of reverse, I tried depressing the clutch several times. I tried lifting the reverse ring. Nothing worked.
Finally with authority I yanked hard on the shifter to pop it out of "R". A grinding noise could be heard.
This has never ever happened to me. It was also embarrassing as hell!
Any clues??? I'm afraid to park it in "R" now, but I have to to get the key out!
Old 07-09-2012, 12:43 AM
Cliff Harris
Cliff Harris's Avatar
There is a cable between the shifter and the steering column. The purpose is to force you to put the transmission in a gear (in this case, reverse) before you can take the key out of the ignition. Been like this for a long time (my '69 Camaro had this "feature"). Probably something wrong with the cable somewhere.
Old 07-09-2012, 12:44 AM
Calderone
Calderone's Avatar
a friend of mine had that problem with his 4+3 , he had to put third to engage reverse, if he didn't do that a grinding noise came out of the trans ! i cannot remember well what was bad
Old 07-09-2012, 06:30 AM
HlhnEast
HlhnEast's Avatar
My 85 must be bypassed somehow as I dont have to do this. I can take the key out in any gear and neutral.
Old 07-09-2012, 09:10 AM
oldalaskaman
oldalaskaman's Avatar
dude, you've had way to much fun in those 22 trouble free years, time to pay some
'corvette tax'
Old 07-09-2012, 10:07 AM
72and86
72and86's Avatar
'corvette tax'
Yeah,,,um...
I've been driving it w/o the OD for 21 years...
And also an issue with the oil temperature running away which allows me to only make short trips, usually less than 30 mins.
Corvette tax? I'm paying it in spades...
Old 07-09-2012, 10:24 AM
oldalaskaman
sorry , couldnt resist
Old 07-09-2012, 11:18 AM
72and86
72and86's Avatar
No problem.
Old 07-09-2012, 11:20 AM
72and86
72and86's Avatar
Is it possible in a senior moment I didn't have my foot on the brake when I started to car, with the clutch. Would that have mattered?
Old 07-09-2012, 12:03 PM
FOURSPEEDVETTE
FOURSPEEDVETTE's Avatar
It's not neccessary to push the brake pedal to disengage the reverse lock. I think the problem may be with the locking ring at the gear shift ****. The plastic ring you lift up to unlock the reverse/park position. Somethings not working right there. The overdrive has nothing to do with you not being able to get it out of reverse.
Old 07-09-2012, 01:39 PM
72and86
72and86's Avatar
Think maybe a shot of WD 40?
Old 07-09-2012, 01:54 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
A shot of Tequila maybe..... wd40 Yuk!
Old 07-09-2012, 03:15 PM
mazdaverx7
mazdaverx7's Avatar
wd40 is a good temporary lubricant, especially for threads and for coating bare metal when its being stored. i would look up the disassembly and service procedure in the service manual and remove the shift **** and inspect the reverse lockout mechanism. you may have a worn part or a stuck part that can be lubricated with grease or graphite.
Old 07-09-2012, 04:36 PM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
If your engine oil temps only allow about 30 minutes of driving, you have more serious problems than the shifter.
Old 07-09-2012, 05:20 PM
72and86
72and86's Avatar
Well yea but that's another whole story and for 21 years no one can figure out why it runs so (oil) hot. Coolant is fine.
Old 07-09-2012, 05:28 PM
72and86
72and86's Avatar
See:
http://forums.corvetteforum.com/c4-t...il-cooler.html
Old 07-10-2012, 02:31 PM
FOURSPEEDVETTE
Take the shifter **** off (can be a little tricky) and move the ring up and down while trying to move the shifter out of gear. See if something is binding causing the ring to not move up far enough. I don't think that lubricating it will fix it. These parts really don't require lubrication. The top black button with the gear pattern needs to be pryed off and then you will see the metal "key" that slides out letting you remove the ****. It's a bit tough to slide it out but it will come out. Good luck!
To 22 Years Owning this 86 and this never happened before...
Quick Reply: 22 Years Owning this 86 and this never happened before...
