Confused: Axle RPO Numbers
I just received the "build sheet" from the Corvette Museum for the '89 C4 corvette I recently bought. It lists two RPO codes for the "Axles" on my car: One code says G44 3.07 AX, The other code says G92 PERF RATIO AX. What is the difference between these axle codes? I thought the 3.07 Axle3 WAS the performance axle...?
The G92 - is a reference to a sales package that could vary in any of the sales areas around the country and depending on "car-line" the ratio can change also. It's not actually "redundant"!
They did pretty much the same thing with the ZF6.
You have MN6 for 6-speed manual transmission.
And also ML9 for the Manual, 6-Speed ZF
Since the ZF6 was the only 6-speed transmission available, it confuses some on why the two codes.
