cleaning throttle body
Old 08-09-2012, 08:02 PM
swiftvetc4
swiftvetc4's Avatar
Default cleaning throttle body
When cleaning the throttle body on my 94 LT1, besides cleaning the plates can I have the car running and spray cleaner inside?
Old 08-10-2012, 10:45 AM
92ragtop
92ragtop's Avatar
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Yes.
However, it's best to remove the TB to give it a proper cleaning. Then you can also use the cleaner with a brush or rag to work on the plenum opening.
Old 08-10-2012, 10:53 AM
swiftvetc4
swiftvetc4's Avatar
Is removing it a big job, I already removed the two coolant hoses
Old 08-10-2012, 11:39 AM
higgyburners
higgyburners's Avatar
I believe in the Beer Fairy
St. Jude Donor '15,'19
It is very simple to do and you wont believe how much crap builds up on the back of your butterflies. After you remove it spray it down with Throttle body cleaner a few times to get all the gum and crap off it, I also cleaned the IAC while I was at it.
Old 08-10-2012, 12:29 PM
92ragtop
92ragtop's Avatar
Once your hoses are off, disconnect the throttle cable and the electrical connectors, remove the bolts, and then a light tap should free up the TB. As part of the cleaning, use compressed air to blow out the IAC orifice. Make sure you know how the proprly reset the IAC when reinstalling. Use new gaskets if the existing ones are anything but perfect.
Old 08-10-2012, 11:53 PM
Cliff Harris
Cliff Harris's Avatar
What's up with that? I have always wondered about that. You're feeding filtered air into the throttle body, so how can it get dirty?
My theory is that it's caused by the EGR -- just a guess on my part.
I guess the way to test this theory is to check with people who have deleted their EGR and find out if their butterflies get dirty.
This also applies to the IAC passages.
Old 08-11-2012, 01:34 AM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I know Google can be difficult sometimes, I hope this helps.
http://www.popularmechanics.com/cars...repair/1272341
Old 08-11-2012, 03:04 PM
pjgiantsfan
pjgiantsfan's Avatar
Does the coolant need to be drained prior to removing the coolant hoses to the throttle body?
Old 08-12-2012, 08:03 AM
swiftvetc4
swiftvetc4's Avatar
I eliminated my hoses all together, extra heat not needed where I live and when I drive, you will have some coolant spill but not a bunch.
Old 08-12-2012, 08:05 AM
swiftvetc4
swiftvetc4's Avatar
What is the IAC?
Old 08-12-2012, 08:39 AM
Mohammed_z
Mohammed_z's Avatar
No , just put a towel under the hoses and keep the hoses hole up so no coolant will spill.
Originally Posted by swiftvetc4
What is the IAC?
Idle Air Controller
Old 08-12-2012, 11:03 AM
pjgiantsfan
Thank You. I have a slight hesitation just above idle. I heard one cause may be a dirty throttle body. I have never done my own work on a car but will learn on my 93
Old 08-12-2012, 11:06 AM
Mohammed_z
Mohammed_z's Avatar
it's an easy job. good luck .
Old 08-16-2012, 11:45 PM
swiftvetc4
swiftvetc4's Avatar
Getting ready to remove throttle body and clean. Book says after removing accelarator cable it must be adjusted before reinstalling, anyone ever have to do this? Looks like you just slide the cable out and then back on when done.
To cleaning throttle body
Quick Reply: cleaning throttle body
