Fan is always on.
Clutch CYCLING. The cycling switch's main function is to maintain as low as possible evaporator temperature without icing. The clutch turns off if pressure gets below the equivalent of 33deg F. About 28psi for R12, 22psi for R134. When pressure rises to about 40-42psi, the clutch re-engages, and draws the low side down again. Over and Over. Hence "Cycling". The evaporator thaws during the off cycles because its temperature rises above freezing.
If the compressor ran continuously under conditions where icing can occur, the evaporator would become solidly blocked by ice formation, airflow would stop, and there would be such low return flow volume to the compressor that it could become oil starved and damaged.
Thanks Roy for the support.
Go read through this thread
https://www.corvetteforum.com/forums...ol-issues.html
Then tell us how stupid we are and answer my question about the clutch cycling on the 94-95 cars. (if you have a service manual available).
My post was an attempt to get back to basics, so the OP could filter out the info that doesn't apply to him. The high side pressure switch that controls his radiator fan is "normally open" (later automatic temp control cars are different), and several have stated correctly that switch may be his problem.
If anyone finds errors in my description of basic a/c operation, I'd like to know about it!
