c5 rims on c4 vette
Old 09-24-2012, 08:49 PM
R84CORVETTE
R84CORVETTE's Avatar
Default c5 rims on c4 vette
hi, thanks for any help, will c5 rims and 225-50r17's tires fit on a c4 vette with out any trouble thanks again
Old 09-24-2012, 10:43 PM
oldalaskaman
oldalaskaman's Avatar
depends on the year of C4 and looking at your avatar I'll guess 84, not with out adapters
Old 09-24-2012, 11:09 PM
R84CORVETTE
mine is a 1984 if you put them on without adapters what would happen also were can you get adapters thanks
Old 09-24-2012, 11:15 PM
oldalaskaman
they sit bout an inch inside the fenders or more depending on which C5's and you get them on fleabay, if you get C5 ZO6, you only need a 3/4" hub centric adapter on the rear.
Old 09-24-2012, 11:30 PM
R84CORVETTE
what happens if you put them on with no adapter? thanks
Old 09-25-2012, 12:08 AM
Calderone
Calderone's Avatar
they don't look right sitting inside the wheel well , you won't like it at all
i've seen c4's without adapters, looking for a picture
Old 09-25-2012, 03:46 PM
R84CORVETTE
do they need adapters for front two?
Old 09-25-2012, 03:48 PM
Calderone
Calderone's Avatar
one for each wheel
i would use 1" inch adapters.-
Old 09-25-2012, 03:56 PM
oldalaskaman
not for ZO6, others yes
Old 09-25-2012, 03:59 PM
R84CORVETTE
HOW CAN I FIND OUT WHAT THE ADAPTERS LOOK LIKE IT MAY HAVE THEM the car has the c5 rims on now but i want to make sure thanks for your help
Old 09-25-2012, 04:06 PM
oldalaskaman
take the rims off, take a picture where they were bolted to the car , post it here only need on front and one rear, actually, just take a pic of the car
Old 09-25-2012, 05:41 PM
QCVette
QCVette's Avatar
The Z06 may need an adapter on the front also.
84-87 base
8.5"x16" 32mm offset
84R-87 Z51
9.5"x16" 38mm offset
88-96 base
8.5"x17" 56mm offset
9.5"x17" 56mm offset
C5 base
9.5"x18 65mm offset
C5 Z06
9.5"x17" 54mm offset
10.5"x18 58mm offset
Compared to the early C4 16" offset, the 17" Z06 wheels will be different by 54mm-38mm=16mm or 0.63" different. So a small adapter like a 1/2" or 3/4" adapter would position them quite close to how the early Z51 wheels were positioned.
Old 09-25-2012, 06:18 PM
oldalaskaman
these are C6 ZO6 aftermarket rims in C5 Z06 sizes, on my 87 track car, I had to add the rear hubcentric adapter, to the rear for them to clear the dogbone mounts, that pushed them slightly outside the wheel well which I fixed with flares. the front fit right at the edge of the wheel well, no issues with turning or rubbing, but I also installed a wider tire on both ends to take up any miss match. hope this helps
Old 09-25-2012, 10:45 PM
R84CORVETTE
Hi, tried to download pictures but said an error
Old 09-25-2012, 11:00 PM
oldalaskaman
upload to photobucket, then right click the pics bottom link and past it to your thread here, hope this helps.
Old 09-25-2012, 11:19 PM
Calderone
Calderone's Avatar
Hey R84 if photobucket did not work
try www.imgur.com
Old 09-26-2012, 12:06 AM
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Check your rim and tire size also as the C5s came with 17" front and 18" rear from the factory.
I have the stock size 17/18s on my 91 with no adaptors and they fit and look great. For those of you with the 84 thru 87 C4s you will have to check the backspacing and purchase the appropriate sized adaptors.
Here is a pic of what they look like:
Old 09-28-2012, 10:59 PM
R84CORVETTE
hi, put 2 pictures on photo bucket but still having trouble sending them sure it me would should i try thanks
To c5 rims on c4 vette
Quick Reply: c5 rims on c4 vette
