No heat.
Old 09-26-2012, 07:00 PM
Berb
4th Gear
Berb's Avatar
Default No heat.
My '84 isn't putting out any heat from the heater, just ambient temp. air. The controls each have resistance and do not seem to have become disconnected. Is there something besides the heater core that could be hanging up? How do you check a core; there are no leaks or smells inside the car.
Old 09-26-2012, 07:48 PM
vetteoz
vetteoz's Avatar
Are the 2 hoses going to the core hot when the engine is hot and heater on "Hot" ?
Has a 84 got the vac operated isolation valve in the engine bay that shuts off the coolant flow ; it may to shut or not operating ?
The valve visible in from of the relay
Old 09-26-2012, 07:52 PM
ScottMA64
ScottMA64's Avatar
Hmmmmm that pic looks familiar.
Old 09-26-2012, 08:22 PM
CREWZIN
CREWZIN's Avatar
It's not only the 84, my 87 had one that broke and couldn't find a replacement.
Found a shop that worked on Vettes and they replaced it with a different kind...that works.
Also, if your coolant is low, I found out that will stop the hot air from working.
Old 09-26-2012, 08:31 PM
vetteoz
vetteoz's Avatar
Originally Posted by CREWZIN
It's not only the 84, my 87 had one that broke and couldn't find a replacement..
That is why I asked , I know the early TPI cars had them but I are unfamiliar with CFI cars
there have been several fixes over the years
http://forums.corvetteforum.com/c4-t...-corvette.html
Another version
http://www.rmsautoparts.com/proddeta...=15-5320&cat=5
Old 09-27-2012, 07:27 PM
Berb
4th Gear
Berb's Avatar
Thanks for the info. I will check to see if there is a valve.
To No heat.
Quick Reply: No heat.
