1986 Corvette with Late Style Bumpers... HOW?? HELP
Old 10-05-2012, 06:46 PM
StaySmokin
StaySmokin's Avatar
Default 1986 Corvette with Late Style Bumpers... HOW?? HELP
I am prepared to purchase a front bumper from a 96' C4 for $100 which i believe is a STEALLL. But what do I have in order to install the front bumper to my 86' , please help!
Thanks!
Old 10-05-2012, 07:23 PM
0RPP_Corvette
Former Vendor
RPP_Corvette's Avatar
It should bolt up with no major issues. Does it come with side marker lights.
Old 10-05-2012, 07:25 PM
StaySmokin
StaySmokin's Avatar
Yes sir i believe it does, i'd have to double check! I heard it doesn't simply bolt on though?
Old 10-05-2012, 08:18 PM
oldalaskaman
oldalaskaman's Avatar
the only differences are the lights and some of the inner braces, all adaptable
Old 10-05-2012, 10:56 PM
cadmaniac
cadmaniac's Avatar
Correct me if I'm wrong, but you will need the bumper cover, side marker lights, fog lights, and the front wheelhouses, plus the licence plate cover......
Then the beltline wont match, so you will need the fenders of a later model.
Then the doors won't match so you will probably want to change out the door mouldings.
Then the rear beltline wont match, and you will want to change out the rear bumper cover, backup lights, 3rd brake light, and taillights.
Old 10-05-2012, 11:14 PM
oldalaskaman
you're right, I used the aci pieces on my 87 and wasnt thinkin, slight brain fart, many thanks
Old 10-06-2012, 05:04 AM
gerardvg
gerardvg's Avatar
The early C4's will need an adapter as there is a 1/2 to 1 inch gap, where they bolt on to the wheel splash shields where the plastic spoilers bolt on.
I did mine more than ten years ago and made adapters so it bolted straight up. They will fit straight onto 88-90 c4's as the plastic wheel splash guards are different.
Of course you need the impact absorber, lights and some hardware from the 91-96 bumpers.
You may want to fit the wide moldings on the doors and later rear bumper they bolt straight up
Old 10-06-2012, 05:33 AM
gerardvg
gerardvg's Avatar
See below the adapter circled and pointed at. (sorry was taken at night with a flashlight. But you should get the idea
See in this picture the fitment from the coke oil catch can, the bumper mounting is further down and the gap is wider toward middle of car, that is your main problem unless you get the later splash guard.
Old 10-06-2012, 06:44 AM
JackDidley
JackDidley's Avatar
It looks like more trouble than its worth. If you want a late C4, it may be better to just swap cars.
Old 10-06-2012, 09:45 AM
WW7
WW7's Avatar
Plus if you ever want to sell the car, most people won't want a car that's pieced together.. They're hard enough to sell when there original......WW
Old 10-06-2012, 10:32 AM
FOURSPEEDVETTE
FOURSPEEDVETTE's Avatar
You might want to think this project over. Adapters, new paint, different fenders, different belt lines, (optional coke can ) different style marker lights, many hours of work and a bottle of aspirin. Is it worth all this for the $100.00 bumper and to constantly have people come up to you and tell you that your front bumper must have been replaced?
Old 10-06-2012, 01:24 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Made my 84 look better and run faster.
Old 10-06-2012, 05:31 PM
856SPEED
856SPEED's Avatar
nice.......that drive train in your car would make anything roll out pretty well, I would guess even the stock body panels...
it's hard to believe that thing started life as an 84!
Old 10-07-2012, 02:08 AM
StaySmokin
StaySmokin's Avatar
Thanks for the help guys! Turns out he sold it a week ago and thought i was talking about the hoods he was selling (how do you get those two mixed up?!). I guess ill just keep this beauty until i can sell it and buy a 96'! Thanks for the help!
Chris
Old 10-07-2012, 02:10 AM
StaySmokin
StaySmokin's Avatar
Looks like ill just need a day at most to do this ...hmmmm thanks for the pictures!
Old 10-07-2012, 06:53 AM
gerardvg
gerardvg's Avatar
I am sure that adapters should be readily available nowadays, there are a lot of early c4's that have been upgraded to the later 91-96 look.
Old 10-07-2012, 01:28 PM
383vett
383vett's Avatar
To 1986 Corvette with Late Style Bumpers... HOW?? HELP
Quick Reply: 1986 Corvette with Late Style Bumpers... HOW?? HELP
