L98 Aluminum Heads - When?
Old 10-27-2012, 01:29 AM
ckwhite
Support Corvetteforum!
ckwhite's Avatar
Default L98 Aluminum Heads - When?
I'm getting so much conflicting information from different sources. So, when did GM begin putting aluminum cylinder heads on the L98 engine? Was it "always"? Or did they start putting Al heads on it in a particular model year? I've got an '89 L98. Does mine have aluminum heads? Was this a good idea - or?
Thanks!
Old 10-27-2012, 02:06 AM
mcm95403
mcm95403's Avatar
Not to be a smart-alec, but a magnet is an easy way to check.
Old 10-27-2012, 02:22 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Mid year 86 started the Al heads.
That was the end of iron heads.....forever (for Corvettes)
Old 10-27-2012, 02:32 AM
vetteoz
vetteoz's Avatar
It " should " but anything could have been done to the engine in 23 years
Old 10-27-2012, 05:23 AM
Pres712
Pres712's Avatar
The aluminum heads started with the '86 convertibles and later in the year went across the board.
Old 10-27-2012, 07:38 AM
WW7
WW7's Avatar
As far as stock heads go.
Perameter bolt heads are steel
Center bolt heads are aluminum......WW
Old 10-27-2012, 11:38 AM
ckwhite
ckwhite's Avatar
1986. Well, that locks it in, pretty well. Thanks to all of you for your responses. Yeah, I might be able to use a magnet to check the heads if my car were not at the shop in Auburn, about 80 miles away... Haven't seen it in a month. I just write checks when they ask for more $.
Craig
Old 10-27-2012, 01:03 PM
ch@0s
ch@0s's Avatar
E86 had iron heads.. L86 and 87 vetes got the 128 aluminum heads. In 88 they went to the 113 heads and are the same heads used on the ZZ4 crate motors. When My 91 had the stock heads I could see the las few numbers of the casting In the oil filler neck.
What are you having done to the car?
Old 10-27-2012, 05:40 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Indeed your '89 Vette came with #113 D-port Al heads; if you pull a valve cover you will see on the head a P/N ending in 113.
Old 10-28-2012, 07:30 PM
ghoastrider1
ghoastrider1's Avatar
the last 12,000 vettes built in 1986 came with the AL.heads.
To L98 Aluminum Heads - When?
Quick Reply: L98 Aluminum Heads - When?
