erasing ECM codes
Old 11-08-2012, 05:07 PM
bill herried
bill herried's Avatar
Default erasing ECM codes
I can't remember how to reset my ECM, and clear the codes. Any help would be appreciated. I have an 87.
Old 11-08-2012, 05:12 PM
lt4obsesses
lt4obsesses's Avatar
The easiest way that I know of is to disconnect the negative battery cable for 10 seconds. If you can get an OBDI code reader they can erase DTC's as well.
Or, if you have fixed the issue, just keep driving and it will turn off. After x amount of system check cycles (starts) and the problem is fixed, the light will turn off.
Old 11-08-2012, 06:26 PM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
Old 11-08-2012, 06:45 PM
Cruisinfanatic
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
take out the ecm fuse for a minute
Old 11-08-2012, 09:43 PM
WW7
WW7's Avatar
that taking the neg cable is the easiest.. I wouldn't screw with any fuses..You will however have to reset the clock and radio channels.....WW
Old 11-09-2012, 03:27 PM
Cruisinfanatic
that's why you remove the fuse rather than disconnect the battery
Old 11-09-2012, 06:56 PM
nutz4c4
nutz4c4's Avatar
Thsts why you unplug the ECM connector on the positive cable rather thann removing the the fuse or disconnecting the the battery cable..
To erasing ECM codes
Quick Reply: erasing ECM codes
