C-4 Battery Drain
Old 12-30-2012, 01:17 PM
7963bill
8th Gear
7963bill's Avatar
Default C-4 Battery Drain
My '94 will have a dead battery in just a few days after a full charge. Battery is new. I pulled the two headlight motor blade fuses and checked the voltage at the fuse block where the fuses plug in. I got 12.5 volts from both contacts on one side of the fuse block. On the other side, I got zero voltage on the right headlight motor and 5.0 volts on the left headlight motor. Is this 5 volt reading an indicator that something is causing my battery drain?
Old 12-30-2012, 02:25 PM
Dr. Evil
Dr. Evil's Avatar
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
It could be but voltage can go both ways so something else could be feeding it. You're on the right track though. I use a fluke meter with an amp draw measurement. I check the draw across every fuse to isolate the problem. Just have to make sure you have the accesory powered off. I'd check the usual stuff light making sure the underhood light goes off, console lid lights go off etc.
Old 12-30-2012, 07:21 PM
vetteoz
vetteoz's Avatar
And if you don't find anything there you have to pull the power feeds off the terminal behind the battery
and meter the wires individually.
Many systems have the power direct from the battery ( through fusible links ) that don't go through the fuse box
Old 12-30-2012, 07:27 PM
rrt898
rrt898's Avatar
Fusible links are almost always the problem....
Old 12-30-2012, 10:29 PM
7963bill
8th Gear
7963bill's Avatar
Thanks for your input. I'll be working on it.
Old 12-30-2012, 10:31 PM
TA
TA's Avatar
Some of mine were corroded to the point they fell apart when you touched them.
Old 12-31-2012, 07:18 PM
Greg Gore
Greg Gore's Avatar
Key left in the ignition draws around 300ma I think. Key out 50, if memory serves.
Old 12-31-2012, 08:24 PM
NuckinFutz93
NuckinFutz93's Avatar
Check you vanity mirror lights. My wife killed the battery in my old 95 by leaving them on.
Old 12-31-2012, 11:35 PM
Cliff Harris
Cliff Harris's Avatar
Some sneaky current draws I've heard about are:
Problem with the power antenna. It doesn't shut off after lowering and continues to draw power.
Power seat (especially if you have the memory option that moves the seat all the way back when you shut off the ignition).
Interior lights don't turn off for some reason. Usually you walk away from the car and don't realize that the interior lights aren't shutting off because you expect the shutoff delay (and then it doesn't happen).
Old 01-06-2013, 03:54 PM
7963bill
8th Gear
7963bill's Avatar
Thanks for the ideas. Going to check the radio antenna closely. It does not retract all the way.
Old 01-07-2013, 09:01 AM
JustDennis
JustDennis's Avatar
The battery drain on my 86 was caused by the right headlight actuator motor. The motor was going bad. With everything off, I listened under the hood and could hear it clicking every 30 seconds or so. I unplugged it and no more battery drain. I replaced the headlight motor this weekend and all is well.
Old 01-07-2013, 10:39 AM
BGZQ8
BGZQ8's Avatar
I have not heard this before about a C4 and I always leave the key in it. Can anyone elaborate more about this ?
Old 01-08-2013, 01:01 PM
bac22
bac22's Avatar
I'm assuming he meant when it's running...otherwise 3A is a hell of a lot of power when the key is in it not running! Normally the vette draws 30-50mA just sitting...anything above that means there is a problem somewhere.
Old 01-08-2013, 04:34 PM
Biker
Biker's Avatar
Yep! I once had one go bad in a parking lot, leaving me stranded.
To C-4 Battery Drain
Quick Reply: C-4 Battery Drain
