Paint Code??
Paint Code??
I have 1986 coupe. I am looking for the paint code. Is it located on the car or is it in the VIN#? I have had many people call my color different names. I think its silver metallic but; there are a few shades of silver.
thanks...
thanks...
Is the Service Parts Identifier sticker (also called the RPO sticker) under the console lid?
If so, the bottom printed line should have the paint codes. They are in the form of 2 numbers and a letter U or L. There will also be a "WA-nnnn number. If the car is silver, there should be a 13U. There was also a Silver Beige Metallic (sort of a tan with silver) that is code 59U Here's a link to 86 color chips Not the best representation but it will give you an idea.
Look here for the WA codes; just scroll down to the 1986 list and they will be in the right-most column
It is printed on your RPO Code sticker.
Look for a code starting with BC/CC
(Base Coat/Clear Coat)
You will see something like U 7781
U = Upper
7781 = Silver Metallic
It might also be listed like this: U 7781 L 7781
L = Lower
And if the car is all one color, both number would be the same.
Received 6,940 Likes
2015 C2 of Year Finalist
The OP hasn't mention why the curiosity - if he's considering some refinish operations a quality shop would do "test panels" first.
It's paint code 13. I have a Silver Metallic 86 as well.
I will retract that. I looked at your gallery. I have no idea what that color is but it is not the same color as my car. It is darker for sure.
I looked at RPO sticker. I have removed the rear compartments so, I had to dig it out. It says bse/clr coat WA - U7719.
thanks for any help.....
