84 front bumper filler plate
Old 03-30-2013, 09:09 PM
Bridges77
Bridges77's Avatar
Default 84 front license plate filler
I was wondering if anyone knew if a filler plate from 91-96 will fit on an 84 front bumper?
Old 03-30-2013, 09:27 PM
don hall
don hall's Avatar
You might check with the various sellers. Corvette Central sells
the plate cover for 1991-96, and 1984-90 as different items.
Old 03-30-2013, 09:28 PM
mazdaverx7
mazdaverx7's Avatar
the 91-96 filler plate is shaped differently and does not fit properly. the 84-90 filler plates work on the 91-96 but the shape is incorrect.
Old 03-30-2013, 09:30 PM
Bridges77
Bridges77's Avatar
Thank you for the reply!!
Old 03-30-2013, 09:33 PM
mazdaverx7
mazdaverx7's Avatar
no problem. i have one of each filler plate and can post comparison pics if you'd like
Old 03-30-2013, 09:34 PM
Bridges77
Bridges77's Avatar
I had both part numbers just needed to know fitability? Thanks
Old 03-30-2013, 09:35 PM
mazdaverx7
mazdaverx7's Avatar
ok no problem.
Old 03-30-2013, 09:36 PM
Bridges77
Bridges77's Avatar
Pics would be great......and thanks again
Old 03-30-2013, 09:59 PM
QCVette
QCVette's Avatar
I have an early and a late one in my garage. I lined them up.
I don't think they will interchange.
The tabs at the top are in different locations.
The height of the main section (top to bottom as installed on the car) is about a 1/4 inch different. The early is a little taller.
The lower tabs and screw holes appear similar.
The shape is different on the face, so even if it fits it may look odd.
Old 03-30-2013, 10:09 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
You really need the correct one. GM # 14049269
The '91+ has holes in the mounting tabs on the upper and they're seperated by maybe another 1".
Google (images) this --- 10285647 GM
Old 03-30-2013, 10:16 PM
WVZR-1
WVZR-1's Avatar
Check your other post for the correct image and part number!
Old 03-31-2013, 07:27 AM
Bridges77
Bridges77's Avatar
Thanks for everyone's help!
Old 03-31-2013, 07:17 PM
WW7
WW7's Avatar
Here's one from ebay...WW
http://www.ebay.com/itm/Corvette-license-plate-cover-84-85-86-87-88-89-90-red-/370785789551?pt=LH_DefaultDomain_100&hash=item56548e266f&vxp=mtr#ht_436wt_666
To 84 front bumper filler plate
Quick Reply: 84 front bumper filler plate
