Heat/Sound Deadeners On Sale **STARTING @ $109.99**
Former Vendor
St. Jude Donor '12-'13
With driving season fast approaching, its time to finally do something about the heat build up from your undercarriage and that droan of exhaust and road noise.
Our complete CNC cut deadener material will create a liner of protection reducing noise and interior temperatures. We have 2 new choices depending on your goals for your Coupe or Vert.
Our ensolite material offers a well-rounded approach to your heat/sound quenching needs. This lightweight material offers great sound killing properties and can lower inside temps 15-20 degrees.
ON SALE $139.99
CLICK HERE TO ORDER:
http://www.corvettemods.com/C4-84-96...ts_p_5565.html
Finally, our advanced kit offers a foil-lined backing and an extra thick middle for the maximum heat/noise blocking. This material carries a R-19 rating!
ON SALE $149.99
CLICK TO ORDER:
http://www.corvettemods.com/C4-84-96...it_p_8119.html
Don't forget to add the door kit too!
http://www.corvettemods.com/C4-84-96...ge_p_5566.html
ON SALE $139.99
ON SALE $149.99
CLICK TO ORDER:
Does this include the transmission hump? While I've got most of the interior out, now would be a good time to insulate it. Is there much weight difference between the two?
Just so you know, I got the advanced foil sided kit and you would not be able to double up on the stock pad. It would be too thick. This kit by itself under the carpet will be plenty enough. Have I tested it out, not yet, but I've pulled out all my old stuff and this new pad would not go over the old stuff and then carpet on top. Seems very good so far.
I installed this kit throughout the whole cabin, including the door panels. It is a very inexpensive upgrade that everyone should do. I highly recommend it. It's easy because the pieces come cut to fit. The stereo acoustics are much improved, road noise decreased by at least 30%. Doors close with even more of a solid 'thump'! Much more cost effective than the Dynamat product.
