Instrument Cluster replacement invalidates mileage?
Old 05-09-2013, 09:04 PM
BB 2005
Support Corvetteforum!
BB 2005's Avatar
St. Jude Donor '11, '13
Default Instrument Cluster replacement invalidates mileage?
Will replacing the instrument cluster invalidate the mileage? If yes, then I will need to get it refurbished. Anyone know a reliable place to get that done?
Old 05-09-2013, 09:06 PM
aboatguy
aboatguy's Avatar
1991 and newer clusters the mileage is in the BCM so no problems.
I believe in the digi dash its an analog odometer and you just bolt it in the new cluster.
Mike
Old 05-09-2013, 09:54 PM
BB 2005
BB 2005's Avatar
I have a 93 so I understand I can replace it without affecting the mileage. Can anyone recomend a refurbish shop or where to buy a replacement?
Old 05-09-2013, 10:39 PM
TsuDeltaChi
TsuDeltaChi's Avatar
Old 05-09-2013, 10:53 PM
zr1fred
zr1fred's Avatar
Yep, mileage is resident in the body control module (BCM or CCM, same thing) in the 90-96 C4's. It's in the instrument cluster 84-89, and in the C5's.
Old 05-10-2013, 12:00 AM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
What is wrong with the cluster that you have?
Originally Posted by TsuDeltaChi
So let me get this straight......If I was to upgrade my interior to white text (instead of the yellow), I could get a 94-96 cluster and my mileage would show up correctly?
You could have other issues in the arrangements of the information in the LCD and the warning lamps are maybe different BUT yes the mileage would be displayed correctly. The LCD components could possibly be swapped from your current to the later so that you could retain proper orientation of the display. Never had a "hands on" but it sounds "doable"!
To Instrument Cluster replacement invalidates mileage?
Quick Reply: Instrument Cluster replacement invalidates mileage?
