Help! Door Lock Stuck - 95 Convertible
Old 07-03-2013, 12:41 PM
JohnnyCanuck
JohnnyCanuck's Avatar
Default Help! Door Lock Stuck - 95 Convertible
I was washing the 'Vert this AM when I seemed to have tripped the latch on the door. The latch part on the back of the driver's door is closed and I can't open it for love or money. All the other locking mechanisms seem to work OK, I just can get the latch open, therefore can't close the door. And yes, I've tried the key. Help!
Old 07-03-2013, 12:51 PM
ch@0s
ch@0s's Avatar
Stick a screwdriver in the latch and pull back while pulling the door handle.
Old 07-03-2013, 12:52 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
You'll need to insert something that can "open" the latch when you lift the handle. Just put some pressure towards the body of the car with whatever you insert and lift handle. Don't insert it to far or it won't unlatch. It might help to have a helper!
Old 07-03-2013, 12:57 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
Yeah, it's spring loaded closed, so lift the handle and raise the latch against the spring pressure till it clicks to the open position.
Old 07-03-2013, 12:59 PM
JohnnyCanuck
Thanks folks. Problem solved. Advice most appreciated. Johnny
To Help! Door Lock Stuck - 95 Convertible
Quick Reply: Help! Door Lock Stuck - 95 Convertible
