Rack and pinion replacement
Old 08-29-2013, 05:29 AM
bsbones
bsbones's Avatar
Default Rack and pinion replacement
My rack and pinion is leaking and needs to be replaced. How long and how much should it cost for this work. I have the new rack but can not get a quote from local repair shops.
Old 08-29-2013, 05:55 AM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
You might try a post in the "Northeastern" section of the forum for a recommendation of a shop that's in the vicinity that comes with a "this is where I'd go" recommendation. It could well be worth a couple hour drive maybe for a quality repair. There's also an alignment or just a basic toe setting to consider while doing the repair!
You don't mention why they won't price it but there are maybe good reasons. Some shops won't let the customer supply parts for several reasons, among them the wrong parts supplied and once the work has started and it's determined the part isn't correct now it becomes the shops time and facilities that are committed, if a shop installs the customers part there's no shop warranty involved and that can certainly create issues when a major part is defective or fails. The shop may not be interested in a repair that isn't something they're actually familiar with and they're trying to avoid using you as the "guinea pig".
Using your steering rack (a remanufactured product) as an example, once it's installed and it either leaks or is defective out of the box who get's to pay the shops time? If they supply the part then the warranty of the shop is involved and they'll likely be reimbursed by the vendor or the manufacturer for the efforts. If yours fails in 60 days what then?
How long and how much? It actually depends on the talent of the technician. If it's something that's done regularly it could be very competitive, not done frequently a shop may want to charge straight time.
You didn't mention year and if it's a C4 it doesn't matter much but your location if it's an older C4 then maybe they consider the likely effects of the "winter" on the vehicle. Some just may avoid older projects.
** You didn't mention where the leaks are and since you've purchased a rack not maybe important but it might have been something to consider first.
Old 08-29-2013, 06:47 AM
bsbones
bsbones's Avatar
It is an early 1986 and the shop that I plan on using has done other work and I have been very happy with there work. When I had them look at the leak they told me it was the input shaft. I do not think they have done one on a corvette although they did say it would take 6 hours. I'm not sure if that is reasonable?
Old 08-29-2013, 11:23 AM
FostersPerformance
FostersPerformance's Avatar
It shouldn't really take that long. Take the sway bar out and its not too bad. Actually, 6 hours is probally right...
Old 08-29-2013, 11:24 AM
vallini
vallini's Avatar
http://www.turnone-steering.com/
These guys rebuild C4 racks, you supply the core. They did mine, do great work & also offer the pumps. Figure around $400.
Old 08-29-2013, 12:53 PM
WVZR-1
WVZR-1's Avatar
It's quite difficult to determine reasonable until you pile it in stacks of dollar bills! The 6 hours @ a "reasonable" & "rational" labor rate might be considered "reasonable" to the consumer if you're comfortable with their work. If that's the rack install, fresh fluid and proper bleeding including the setting of the toe then it might well be reasonable. How much is the 6 hours going to cost? Can you do it yourself? Are you comfortable doing something like this yourself? It's all "relative"!!
Do you need to send the core back to someone? Hold it until you're comfortable with the repair. If it's a rack that's never been serviced/rebuilt and maybe a Z51 (2 turn rack) - it consider keeping it and selling it to someone wanting a 2 - turn rack.
Old 07-05-2014, 03:31 PM
Stephen Whited
2nd Gear
Stephen Whited's Avatar
Default rack and pinion?!?!?!?!
I have a 1988 C-4 corvette and the power steering went out. It is not making any noises or grinding, its just a bear to turn. Should I bee looking at the rackand pinion instead of the power steering pump? PLEASE HELP!!!!!!! Also, no visible leaks at all.
Old 07-05-2014, 05:11 PM
coyotejoe
coyotejoe's Avatar
I changed mine myself in about 5 hours just fallowed the service manual wasn't that hard. On '84 C-4.
Old 07-05-2014, 05:34 PM
Stephen Whited
2nd Gear
THX. After doing a little more checking, my power steering pump has a low end whine. Could this be as simple as a pump? Is there any way to check?
Old 07-05-2014, 06:14 PM
Red89'-L98
Red89'-L98's Avatar
FL Events Coordinator
St. Jude Donor'13
It took me about 4 hours maybe 5 at most to do mine. It was my first time doing it too. Undid the sway bar and it was simple from there on out.
Thankfully I have lifetime alignment through firestone so I can go have my car alignment done once a week if I wanted to.
Old 07-05-2014, 11:24 PM
Dale002
Dale002's Avatar
This thread is a year old
Old 04-23-2018, 07:20 PM
J-berman
J-berman's Avatar
My C-4 1985 Rack and Pinion leaked but when I started using Lucas stop leak, it stopped. Then I let my tire place replace the unit and it leaked worse, to the point that they refunded my money. Using Lucas it still periodically leaks, but no where near as bad, and the Corvette place by my house in Bellflower, CA told me that it would cost about $350.00 to replace it. Does this sound reasonable?
Old 04-23-2018, 08:07 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Now it's 5 years old.
Old 04-24-2018, 12:16 PM
J-berman
J-berman's Avatar
Well, I guess that I just arrived at the party, but does about $350.00 sound reasonable?
To Rack and pinion replacement
Quick Reply: Rack and pinion replacement
