Replacement Jamb Switch
Does anyone know where I can get a replacement driver's side jamb switch for a '90?
I took the fuse out to keep the interior lights from popping on. That's been fine, but it'd be nice to have use of my radio, heat, and A/C again
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
As mentioned, I couldn't find anything new.
I got used ones from corvettenutz
Check and see if the rubber coating on the switch is worn off that rubber closes the switch just the right amount when the door is shut.
I at first shimmed my switch out, then I found a small rubber cap in my tool box that fit over the plastic plunger and now the light doesn't come on problem solved.
