gasket
gasket
hi guys
two question for you...i rebuilt my 350pc on my corvette 1984 and i need to know if you put a gasket between the oïl pump and the crank cap and also between the oïl filter adapter and the block....thanks
There is no gasket between the oil pump and the cap.
Not sure on your 84 about the oil filter adapter to the block. I don't think there is one there either.
Some people use the gasket between the filter adapter and the block because it comes in some gasket kits. Generally it is not used though.
