need a smog pump gasket - GM discontinued part - ???
Old 11-26-2013, 07:55 AM
Joe C
Joe C's Avatar
Default need a smog pump gasket - GM discontinued part - ???
for some reason, i'm having a problem locating a gasket for the AIR injection control valve pipe. original part number is 14015367. basically, a gasket between the smog pump, and the pipe that connects the control valve. seems like it's discontinued from GM (and AC Delco-???), but someone should have a replacement - can't seem to find one. any suggestions?
TIA...
Old 11-26-2013, 08:04 AM
WW7
WW7's Avatar
That's a pretty simple gasket, go to one of the auto parts stores and they should have something that will work ( it looks like a egr crossover pipe gasket).. If they have nothing to fit , cut your own from a sheet of gasket material, should only take a few minites.....WW
Old 11-26-2013, 08:11 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
There's likely stock on dealers shelves in your vicinity. Way to much time is spent attempting to "source parts" on the Internet. If a local doesn't have it I would certainly think they could give you a couple dealers close and you could have the damned thing mailed. I'd think it a "non-issue"
I believe you're new to the area you're located in. it's time to create a relationship with the GM parts guy. ACD jobbers don't seem to be as accommodating with similar services.
Like WW mentioned "fabricate it"!
Old 11-26-2013, 08:31 AM
Joe C
Joe C's Avatar
found one - just wasn't looking in the right place. thanks...
To need a smog pump gasket - GM discontinued part - ???
Quick Reply: need a smog pump gasket - GM discontinued part - ???
