St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
Originally Posted by STL94LT1
Charge the battery.
The "SYS" flashing every minute or so indicates an electrical system fault.
The number one cause of that is a low (or almost dead) battery, or a bad/weak connection somewhere.
But with that said it is also worth mentioning that if you have an aftermarket stereo, that could also cause it.
I had the same thing happen with mine. Charged the battery and it disappeared until the battery lost charge again. Changed out the 3 year old battery for new. No problem since.
