Coolant Leak, think I've located the problem, Help!
Cruising
Working on my C4 yesterday, I had the hood popped and the engine running, as I was running some gas treatment through it (the man I bought it from let it sit, and I wanted to make sure there was no moisture in the gas). Anyways I parked it and all of the sudden I noticed steam and visible leaking coming from the area of the coolant recovery tank (or overflow tank, or pressurized expansion tank, not sure the proper name). Anyways I shut the engine off and let it sit. I went out this morning with the engine cool, topped off the coolant (It leaked a lot, but needed even more I think it might have been low). Started up the car to locate the leak, and sure enough after idling for about 2-3 minutes, I hear the steam and see the leak. This time I took some pics to document the exact leak spots before turning it off. I was going to replace the tank, but is this all it needs? Thanks for looking.
It could be a bad cap or a cracked tank. Look for cracks in the area of the neck of the tank. Also check to make sure that the line to the overflow tank, which is located in front of the passenger tire, is not blocked. If the line is blocked then there is nowhere for the water to go when it expands as it gets hotter. It will find another way out.
Your new.....so advice. Always give us the year of your car. It makes a difference because the model years are different. If you find that the tank is bad, then I would also look at all the hoses and consider replacing them all. There are several 3/8 hoses that are crimped to aluminum tubes on the passenger fender. You can't buy the replacement part. But you can cut off the crimp and remove the hose and replace the hose and use hose clamps. Note that the one of the tubes is restricted an one end and often plugs up.
I had the same problem. It turned out to be the short brass pipe loose where it fits into the header tank, just inder the cap. It was leaking under pressure. I sealed it with Araldite, and blew some satin black over the repair (bodge!!). I intended to replace the tank, but still haven't 15 months later. It's still Ok. BTW, my wife calls me "Tight ***"
