Turn Signal Problem, Need Help!!!
I need help, hope someone can help.
I have a 88', the left front turn signal bulb and the side marker bulb does not power "On" with the parking lights "On" and the turn signal does not function. They function as they should with the parking Lights "Off" The signal light in the dash also is on when the parking lights are "On", but not when the parking lights are "Off"'
The Right side functions as they should.
However, all bulbs work when the four-way flash is engaged. The right-hand side of car works fine both with parking lights and turn signals.
