1984 antenna mast replacement...
I've been able to successfully take apart the antenna case, but I am having trouble removing the old mast. The ribbon cable was broken and so was the mast, so it was time to attempt the repair.
When I pull on the mast it stops near the top as I pull on it, but will not pull out. I don't want to force it or bend it. Is there a secret to removing this so I can press in a new mast.
Any help would be appreciated.
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
If this is like my '90, the "black" piece surrounding what's left of your mast right at the base is actually a nut. If you look carefully, there are two flat spots on either side of the nut. You should be able to grab it with needle-nose pliers and spin it off. Once the nut is free, the mast will pull off from the assembly.
Thank-you Joel and ghlkal... It took two seconds once I saw the threaded piece on the bottom. Very frustrating that there are no instructions available on this repair.
