What did you do to your C4 today?
#763
Finished out the motor install, drove it a few miles, got it home, and it spun another bearing. I am literally shaking with rage. Only thing that went bad was that one oil pump drive gear mishap, must have been enough to trash the internals. I am just completely ****ing done with this car. Cutting my losses and selling it.
#764
Replaced the radiator tee to throttle body bypass hose. Had a small amount of seepage, want to protect that optispark. Can't really see it very well, but it's there.
#765
#766
I had to take off my starter and replace the connection from the battery to the starter. A female connection 10-12 gauge. This failure resulted from the 112 lobe. At red lights the lobe creates vibration. An oil change I discovered 3 bolts and nuts on one collector had rattled off. The noise was there but very slight and I put off getting underneath to inspect. I went Ace Hardware and bought bolts and some nuts that won't back off. I believe they have plastic inside the threads. I now get underneath the car every month and inspect the collector nuts and bolts just to make sure.
#768
Last weekend I had the car dyno tuned to have a max output of 425 RWHP with 10 lbs of boost and 468 RWFTLBS of Torque on a Mustang dyno
#769
Concluded the Water Pump Chronicles. Ok, so thats an upsell. But hey, my first job on a C4 and I managed to replace the WP and t-stat without soaking the well running opti and everythings looking good after a test run. Excited to get her back on the road.
#770
Any waterpump change without playing uboat commander with the opti is a win
#771
If there was a youtube video of when I removed the t-stat housing bleeder screw, it might get a few views. There may have been expletives as I clumsily fumbled to get it screwed back in. No harm, no foul though. Shop rags were in place already.
#773
Well Im training myself for doing the wheel bearings on the back of my vette one day.
Im actually putting new wheel bearings on the wifes bmw but its the same setup just hella harder than the vette will be if I ever need to do them
#778
Adjusted my TV cable on my '84 so the damn thing would finally shift right. Feels a whole lot better now!
Also learned that my mystery aluminum heads are Edelbrock Performer Centerbolts.
