What did you do to your C4 today?
#1142
Speaking of the air dams, I replaced the center one in summer (definitely helped it breath better at higher speeds in the desert heat) but when I went to replace the side ones, I got a bit confused and decided to put it off (it was too hot that day, and the side ones function fine, just look worse for wear).
Anyone have a quick explanation how to remove the side air dams?
BrandensBeast (11-24-2015)
#1144
#1146
I repaired the rear compartment on our 1992 LT1.
The door would not latch; adjusted the catch assembly with a Philips screwdriver. 5 minutes total.
Life is good.
Life is good.
#1148
If you look at the picture that shows the bottom of the side pieces, there are 5 bolts. That is it. I am not sure what they thread into however. It might only be the fascia and I am not sure if there are any metal threads mounted in the fascia. So when you are putting it back be careful to not over tighten the bolts. You can feel when they snug up and are seated, just don't crank down on it or you might strip them.
#1149
replaced a reverse bulb
new cap on window washer bottle
new hose on wiper pump, then found need more hose for from t to driver side
fixed wiper motor, would not go into park appears to have been a ground issue, works for now time will tell
found out lp light had wires pilled out of it new socket on order
dropped spare need a new one
pulled tires to check brakes tried polishing wheels but not doing much good, any ideas?
rotated tires side for side so ya all can stop picking on us, lol
think that was it for today
#1150
Took a trip to the nearest pic a part yard and went scavenging late 90's Maximas/i30's for rear Bose amps since mine were buzzing all kinds of racket. All the Maximas I saw didn't have the Bose option, but I got lucky and spotted a '98 i30. Yanked those suckers right out of the trunk, called them "speaker switches" at the window and the dude only charged me $2.75 each! Installed them tonight and man, what a difference. Sounds great. First time I've actually had good tunes in my 'Vette. Can't believe I got a pair of working rear amps for $5.50. Its like stealing candy from a baby.
Also, just before replacing the amps I finally got around to replacing the side air dams. Was a lot easier than I thought it would be, actually. Piece of cake.
#1152
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Few days ago I installed a Mishimoto baffled catch can.
#1155
Anxiously checked the progress of the storm moving West to East as my "new" Ruby 40th travels E. to W. (NM from VT) through or around it on a transport truck. Getting excited now!
#1156
I got 275-40-17 sumitomo a/s p01 tires put on in place of nasty dry rotting 255 nangkang front and 285 eagle f1 rear tires on my 9.5" a molds. No tracking issues with them and they are surprisingly quiet. Smooth up to triple digits as well as handle the rain awesome too! Hooray for easy tire rotations too now.
#1160
Weather here in NW Oregon has been so good that 87 has been uncovered, and driven every day for the last 5 days. Cool in the mornings but 45-55 afternoons. Today wiped it down, put it in its stall, hooked up battery tender and installed car cover after another nice days of golfing.
