Ramps for C4 front/rear
Hi all,
I'm looking for a good set of ramps for my 1992 coupe. I found these Rhino ramps that seem to be popular. Is anyone using this (or anything similar)? If so, any issues with clearance on the front?
http://www.autozone.com/autozone/acc...er=366075_0_0_
Hi all,
I am going to buy some 2x10 and build an approach ramp to bolt on to my ramp. much cheaper than buying the extensions.
Former Vendor
Father's Day Special on Race Ramps
The standard RR-56-2 and RR-XT-2 ramps will work great with your C4.
You can get a good deal thru the end of this week and you will also qualify for a free pair of wheel chocks.
http://forums.corvetteforum.com/c6-v...ice-ramps.html
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Hi all,
I use the rhino ramps for the Vett and all my other cars..I just set a couple of custom cut 2 x 10s in front of the ramps so the air dam clears. They work GREAT.
Same here, but after reading the many reviews of them failing, I'm a bit wary of getting under a car with them. Before every use, I inspect them closely. I recently discarded a set that had a minor crack on the bottom of one ramp. It probably wasn't an issue, but who knows. I also partially support the car with jack stands and my floor jack when on them.
If you really want a good set of ramps, you can't beat race ramps. The are light and they don't slide even on my epoxied floor. They come in two pieces for easy storage and the approach angle works for Corvettes without having to use 2x's
