Best Oil to use in LT5 Engine
Thank you for the Info in regards to the oil drain plug. I assumed there was only one but wanted to verify that. If one was to leave the car over night draining out the old oil in the cooler and put in the new oil next day wouldn't that be better then leaving the old oil in ? Thanks again
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Light valves and no rockers or pushrods, and very light lifters = low spring rates. These factors go a long way to reducing the amount of point contact pressure than grinds flat tappets to dust. However, there are 4 cams, and the motor has to come out in order to change and phase them. Parts and labor to re-cam an LT5 and replace lifters is close to $4K, give or take. There is little or no problem finding the proper oil at comparable costs. So, why not select the one with the ZDDP levels the motor was designed to use?
Yeah, whatever 10w30 is available every other year, is what goes in my L98. I only drive it about 100-200 miles/year.
On a side note related to the M1 vs other synthetics:
For 3 years, I was a fan of Mobil 1.
My '11 Ford Escape, which came from the factory with Motorcraft synth oil, has had M1 5w20 since 2012.
The engine suffered #6 piston and cylinder wall damage at 30K miles, and Ford replaced it with a remanufactured engine this part June.
Now, this is my first experience using M1 oil and filters (quite expensive filters too I'll add), but it's enough to make me switch.
(In over 40 years of oil changes, I've never had an engine expire in normal use like this Ford gets).
The SOs '15 Chrysler only recognizes Pennzoil as an approved oil (Mobil Syn doesn't have certification from FCI yet), so I'm switching to Pennzoil full synth for both the Ford and Chrysler.
Best oil for LT5 engine.
