weird clatter noise. help!!
Hi!
I have this weird clatter noise somewhere around left rear tire. Everytime when I drive over bumb. I cant localized it.
Below is link to pic that I took under the fender. It seems that something resonates between that cubicle(what is that anyway?) and body. Cant reach there anyway.
Dont know if the noise is coming from there but somethings wrong there.
http://rs273.pbsrc.com/albums/jj203/vessanpontto/20140625_202025_1.jpg~320x480
Hi
Check all nut and bolts are tight for the various brackets, antenna included you have to get your arm right up to where the antenna assembly and make sure it is secure. the shock absorber is the most likely culprit, check the upper and lower mounts and make sure the shock absorber top shaft or mount has not broken.
By the way you can click the IGM in photobucket and it will show 'copied' then paste it in your message. (that will give you some privacy with your images)
Thank you for replies and "privacy tips" I'm not so good with these photo-uploading systems. I used to use dropbox, but that doesn't seem to work correctly.
That sway bar sounds intresting option. Have to check it out today if its not raining again.. Lets hope that nothing is broken and its just some loose bolt or something.
And sorry my english. I'm from finland
