headlight beeping
Old 07-02-2014, 08:01 PM
86 pace car
86 pace car's Avatar
Default headlight beeping
On my 86 when I turn on the headlights I hear a beeping why is this both my headlights work thanks
Old 07-02-2014, 09:56 PM
gerardvg
gerardvg's Avatar
There is a chime in the dash when you have the headlights on without the engine running, there is no beeping just "ding"ding"ding"ding. or when you open the door with keys in the ignition to remind you.
You can remove the chime.
My 85 doesnt make beeping noises?
Old 07-03-2014, 04:18 PM
86 pace car
I guess its the chime where is it located thanks
Old 07-03-2014, 05:20 PM
Ray Quayle
- 1986 Original Owner -
Support Corvetteforum!
Ray Quayle's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Before you go digging behind the DIC for the Chime Module, check your GAGES Fuse!
Old 07-04-2014, 10:30 AM
86 pace car
Well I changed the fuse and the noise went away and my anti lock warning light went off how come my gauges always worked even with the blown fuse
To headlight beeping
Quick Reply: headlight beeping
