Climate control dead after pulling stereo
07-03-2014, 07:05 PM
My digital climate control is now dead after I pulled the radio out, and put in back in. Any ideas?
07-03-2014, 09:24 PM
Quote:
Originally Posted by
Geardo
Wiring harness on back of climate control popped off when you put the radio in?
07-03-2014, 11:59 PM
what year? did you have the battery disconnected when you did it? if not maybe something got shorted, check the fuses
07-04-2014, 10:30 AM
solaris_vii
It's an 87, had battery disconnected, checked fuses. Pulled C68 controller out reseat plug, and it's still dead!
07-04-2014, 01:02 PM
Checked the voltage to the controller, only 1 volt
07-04-2014, 01:53 PM
Geardo
There are only two fuses involved.
The Gages fuse should have 12 volts on it with the ignition On.
Ctsy/Clk fuse is hot all the time.
07-04-2014, 02:34 PM
Hooked on Vettes
no power on the gages fuse, fuse is good
07-04-2014, 02:39 PM
Geardo
fuse looked good, fuse has 0.1 ohms with a meter, replaced fuse, and have power to a/c controller.
thanks, thats a relief
