Different wheels on my 85
I recently found an older set of Enkei mesh wheels, I have been wanting to replace the 92-94 wheels that are currently on the car since they are not the correct wheels for this car and thought these would look good. What do you guys think.
Before
After
Before
After
St. Jude Donor '17
I like them, but mostly because I don't care for any of the standard wheels for our cars except the ZR1 type. I will say though that I am "old school" in my preference for shiny silver/chrome wheels
They look good!
They look good!
not a big fan of after market wheels in general, but those are very nice! much better than the saw tooth (my least favorite C4 wheel) I even like the turbines better. the 6 spoke '88 are my fav. for early C4's
I have had those on both an 86 coupe and an 87 vert. Mine were made by Riken. Always liked the look.
I have always liked the way these wheels look on an early C4, so when I came across these for $75 on craigslist I snatched them up quickly. I will have to find the correct center caps eventually but for now they will do.....
i've been trying to find out what these were...on my 85....can't get them cleaned up.....tried everything...aircraft stripper...just can't get them down to where I can polish them.....how did you restore them?...
didn't know these were two part wheels, I was told the bolts were cosmetic by a tire shop.....thanks for the info...
by the way...op...your wheels look great
Rims
With 3 sections coming together in the bead area, how are they sealed or do you run tubes in them? Just curious.
Had the 16 inch Enkei's on mine for a few years. I used the 84 black center piece to keep them all one color. Wanted to upgrade to 17 inch wheels so I sold them to someone on this forum.
You need to use a good silicone surface sealant or the wheels will leak. I used Dow Corning 832 multi-surface sealant. You also need to cross-torque the nuts & bolts with blue Loctite or you will have issues. The advantage of 3 piece wheels is you can change you offsets with new barrels/lips it is very expensive but what of quality is not. I have a set of center lock BBS wheels used on an IMSA racer back in the eighties I have been saving for a 1970's Greenwood Corvette replica that I want to build in the near future & I will have to have new lips & barrels made to fit the wheels within the fenders so it will work with street tires. I look forward to that project.
