Passenger side window stuck
I was getting lunch today and went to roll up and the passenger side window and it only went up half way. I didn't notice it until I came back out and tried to roll it down with no luck. I did not hear any sound or anything out of the ordinary. The switch is not functional, I hear no motor sound when I press the switch, and I can not push the window down or pull it up with as much force as I wanted to apply without breaking anything.
Searched the forum only finding various ribbon problems, but it seemed generally you still hear the motor running with those.
Best course of action to at least get the window back up? Its kind of cloudy out...
what year?
Sounds like a motor failure...
does the driver side still work?
To test if it is a motor, slam the door real hard and see what happens... if it works, then it's time to replace the motor.
Slammed the door real hard, worked, window up. Will start looking into motor replacement, are there any other things I should do while I am in the door that commonly need repaired or things I should look at as well?
Thanks for the help!
