corvettemods splash guards for 89 corvette
3rd Gear
Has anyone have any experience with the splash guards p/n 5980 from corvettemods?
1. quality
2. ease of installation - they are supposed to be pre-drilled for ease of install.
3. any installation tips would be appreciated.
Looking to purchase some for my 89 conv. Just purchased 3 weeks ago. Having a mid life experience according to my daughter when she found out I bought this car.
thanks
crane
1. quality
thanks
crane
Cruise-In II Veteran
Though I didn't get mine from that vendor, I've a similar looking set on my 35th Anni since 2000 and holding up very well. When I dress the tires I use the same material on these with good results.
They keep most of the road crap off the rocker panels and rear quarter. Since I'd made many 100s of passes down the 1/4 mile I had to periodically scrape off the burn-out rubber and still they look good.
They do come pre-drilled and use existing OEM fasteners.
I used a Torx bit in a 1/4" drive socket for the rears; turning the front wheels to lock facilitates installation of the fronts.
Enjoy your new '89 Vette; gives us some details and maybe some pics.
Mud Flaps
They don't looks to be the same but I do have mud flaps on my 86, they came with it.
I don't do any off highway type driving but they did spread some rock on the streets here and the flaps do keep the rocks off the car. These bolt onto the edge of the fender well using existing holes and there is a small bracket that is screwed onto the fender on the back of the flap. These are 3 dimensional so there is a small void/pocket in them. I had to replace one of mine (damaged before I bought the car) so when I did I took some foam-in insulation and filled that, makes it much more solid. The replacement came from either Corvette Central or Eckler's, don't remember which but it was one or the other.
If the ones you're looking at are the same, this is my experience. If not, these are an alternative.
My experience is they don't do much, especially on the front. They do keep the first few inches cleaner but the rest is still going to get pelted.
Also the ones pictured above scratch the paint where they rub on it. One of my cars had a line worn in from that exact style
3rd Gear
