power lock fuse location
Old 08-15-2014, 12:24 PM
brdd
Support Corvetteforum!
brdd's Avatar
Location: Minnesota in the summer, Las Vegas in the winter
Default power lock fuse location
Neither one of my locks will operate. 1991. Everything else seems to work. Can someone tell me the location of the power lock fuse? Thanks
Old 08-15-2014, 12:32 PM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
For '91 there's a 15AMP fuse in AUX Box #1 that's under the right side hush panel. There's also a 30AMP circuit breaker in the main fuse block that controls that circuit.
If you don't know how to access it the first few minutes of the video will help you:
Old 08-15-2014, 01:33 PM
brdd
brdd's Avatar
Corvett CDM Tuner Receiver Box Removal and Repair 1990-1992 - YouTube
Thanks for the reply. But you've given me way too much credit.
Which 15 amp fuse runs the locks? My "courtesy" fuse is good. That one runs the door lights. Also, where is the "main fuse block"? Forgive my ignorance please.
Old 08-15-2014, 02:27 PM
WVZR-1
WVZR-1's Avatar
In AUX Box #1 under the right side of dash the fuse will be marked PWR DOOR. Main Fuse Box is at the right side of the dash and is in that video I believe. If you found the CTSY fuse that's is the "MAIN "
Here's some images of '90 and '91 fuse boxes, the '91 is the one shown in this link with 2 AUX BOX's. The PWR ACCY breaker is 4th from the top. Start at the AUX BOX - PWR DOOR fuse.
http://forums.corvetteforum.com/1581564067-post48.html
Old 08-15-2014, 04:04 PM
brdd
brdd's Avatar
Those pictures and instructions are excellent. Thanks for your help. Believe it or not, I used to know this stuff. A few years go by and I can't seem to remember much. Welcome to getting older.
To power lock fuse location
Quick Reply: power lock fuse location
