Hatch Stays Closed
Hatch Stays Closed
When I press the hatch open button, I hear it unlatch but it doesn't automatically raise. I can hold the button and push it open, but it pulls closed. It's like the shocks on it magically reversed - they want to pull it closed instead of push it open. It was working just fine, but now it does this. I'm hoping there's a simple answer out there.
Sounds like both of the struts are shot. The glass hatch is pretty heavy and if the gas pressure in the struts is too low, it will seem like they are trying to close it.
I would suggest replacing the two struts.
EDIT: Correction. I think he just had one replaced.
The glass may also be stuck to the gasket. Try and see if you can raise it by grabbing with your fingers and oulling up. Mine gets stuck sometimes and I sprinkle a bit of talcum/baby powder on the gaskets. If the glass comes right up with your fingers, the struts are bad as Cruiser suggests.
Here they are on "Corvette Central" shop around for the best price.......WW
http://www.parts123.com/parts123/yb....5Z50000050F~~~
Ebay seems to have the best price around..Plus Free shipping.......WW
http://www.ebay.com/itm/2-Corvette-1984-to-1996-Rear-Hatch-Window-Lift-Supports-Struts-Strong-Arm-/231098989304?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item35ce92baf8&vxp=mtr#ht_5448wt_1610
2 Corvette 1984 to 1996 Rear Hatch Window Lift Supports Struts Strong Arm | eBay
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
That glass hatch is heavy!
Support it with something to hold the weight when replacing the struts!
Otherwise, plan on having a secondary problem like a wrenched back or something worse.
