Weatherstrip Installation
I will be installing Willcox windshield weatherstrip on my '86 coupe. They say to clean all weatherstrip bonding surfaces with reducer or thinner. You must remove all mold release agent from the weatherstrip before installing. What do you use to do this? Can the same product be used to clean the weatherstrip and remove any mold release agent?
They also say to wipe a small skim coat on the part and on the car where the weatherstrip is to be installed. What product is used for this?
Any help would be greatly appreciated. Thanks!
Hi...Was reading the same information you did from Wilcox. The adhesive is the skim coat they refer to. If you don't have the adhesive,which they sell get some good stuff. I did about 90% of my 89 and followed the instructions about cleaning and how to use the adhesive, no problems 6 years after. It's not a difficult job but it needs to done right. Good luck with your project, my 93 will get new weatherstripping this winter. Plan on buying mine from Wilcox, great reviews and looks like they make a great product at a fair price.
Cruise-In II Veteran
When I did my '88 I used WS adhesive solvent, safe for paint, from AutoZone. I cut some popcycle sticks to square ends and used them to scrape off any old adhesive after softening with the solvent.
I did the WS install on a hot sunny day to assure the WS could be easily stretched and moved as needed.
