Vats key info........
Most of you know this, but for those who don't, it may be helpful.
I have been using the original ignition key for my 1992. The vette started perfectly every time, but when inserting the key into the ignition, the chime was not always audible. I thought the chime was just 'tired' after 22 years of operation.
I purchased spare ignition keys (3) today, and now my chime works perfectly. I guess the VATS key was the unit that was 'tired'.
Searching for key blanks, I found the unit price fluctuated from about $7 to $42 on ebay, dealers, and locksmiths.
I found this shop that sells GM VATS key for $3.36/ea with free shipping: http://replacemyremote.com/checkout/cart/
To order key blanks, you will need to measure the resistance of your ignition key (simple):
My local locksmith charges $5/key to cut the blanks. I'm sure your local locksmith will only guarantee the 'cut', and not the resistance, so make sure you provide the correct blank
To order key blanks, you will need to measure the resistance of your ignition key (simple): How to Measure a Vats Key - YouTube
