Thoughts on Headliner Adhesive
Old 09-12-2014, 10:19 AM
pcolt94
pcolt94's Avatar
Default Thoughts on Headliner Adhesive
I have done several headliners over the years and used several kind of spray adhesive glues. Getting ready to do another one and was going to get a 2 cans of the 3M headliner glue.
There are a couple of other ones out there that are less expensive like Permatex and Home depots Super 90. Not much for reviews on any of them and just don’t know if I should go with the known best and not mess around trying to save a buck or two.
Just seeing what feedback I may get on this.
Old 09-12-2014, 12:13 PM
GKK
GKK's Avatar
I always use 3m's Super 77...
Old 09-12-2014, 12:32 PM
MRPVette
MRPVette's Avatar
I have done several headliners over the years and never had a problem with the 3m adhesive.
Old 09-12-2014, 01:07 PM
QCVette
QCVette's Avatar
Maybe not the best test, but I used the Permatex spray adhesive on my Buick.
It was only detaching around the edges at the front and back windows. It was only loose for a couple of inches in from the windows and several inches wide.
I sprayed the Permatex and pushed the headliner into the glue. It was sticky enough but loose enough that I could position the headliner fabric and smooth it out to get it in place. When it dried, it was firmly in place.
It held for the couple of years that I had the car.
Old 09-12-2014, 02:05 PM
pcolt94
pcolt94's Avatar
There is a whole line of glue products that are Super 77 labeled.
All have different names and uses.
Old 09-12-2014, 02:08 PM
GKK
GKK's Avatar
3M Super 77 Multipurpose Adhesive, to be more specific...
Amazon Amazon
Old 09-12-2014, 02:48 PM
zr1fred
zr1fred's Avatar
The 3M super spray adhesives work best, the cheaper products and 3Ms regular strength don't hold up (I made a pun!) on headliners. Or you could use regular brush on contact cement.
Old 09-12-2014, 09:48 PM
Heysailor
Heysailor's Avatar
This has worked well for me on several headliner projects...
Old 09-12-2014, 09:52 PM
jake corvette
jake corvette's Avatar
I have used the 3M stuff - both black and yellow. Comes in a tube. Great luck with both. Cannot remember using anything else.
Little more pricey maybe, I dunno - but with known results -
Jake -
Old 09-12-2014, 10:09 PM
Ozzstar
Ozzstar's Avatar
Here you go, Spermatex headliner and carpet adhesive from autozone, $12 and sticky as hell. This video will show you how i did it. Have fun- Ozz
Old 09-12-2014, 10:10 PM
Drycreek
Drycreek's Avatar
As above have used the 3m 77 for years with excellent results.
Old 09-15-2014, 04:21 AM
tintmandevin
tintmandevin's Avatar
Depends on what you're sticking up there. Insulation will fall down in summer heat. If only using fabric or leather 3m may work, but if u glue leather to insulation it'll fall off in serious summer heat. For my third try Im using contact cement to hold insulation to roof. 77 works to hold leather to insulation just not insulation to roof
Old 09-16-2014, 03:15 PM
five7kid
five7kid's Avatar
Originally Posted by Ozzstar
Here you go, Spermatex headliner and carpet adhesive from autozone, $12 and sticky as hell. This video will show you how i did it. Have fun- Ozz http://youtu.be/RjFHHly6yWQ
Is it just me? The only sound I hear on this vid is music (and only part-way through).
Old 09-16-2014, 04:15 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
I'm shocked that the guy doing that video didn't install new headliner. All he did was scrape the old foam (that used to be on the back of the material) off the backer-board and glue
Old 09-17-2014, 08:34 AM
Ozzstar
Ozzstar's Avatar
Don't be shocked Cruisin, the headliner looks and works perfectly and it's OEM material. Future NCRS??
Ozz
Old 09-17-2014, 08:35 AM
Ozzstar
Ozzstar's Avatar
7kid, thanks for making me aware of the audio problem, it is now fixed and should be working well. Sometimes YTube does some crazy things on it's own. It's the nature of the beast when posting vids. Take care and thanks for watching!
Ozz
Old 09-17-2014, 09:26 AM
pcolt94
pcolt94's Avatar
Those were my thoughts also but I thought I missed something or it was my miss understanding.
I ended up going with the 3M headliner after all. Used it before and know it works good.
To Thoughts on Headliner Adhesive
Old 09-17-2014, 09:55 AM
Cruisinfanatic
Ozz
don't know how it can look or feel all that perfect with no foam.
Old 09-17-2014, 11:58 AM
pcolt94
pcolt94's Avatar
You would think if the proper amount of adhesive was used, it would soak thru the material and leave dark and uneven spots.
Old 09-17-2014, 12:25 PM
tbirdsps
tbirdsps's Avatar
I've always used 3M #80 'cause it's so stinking hot here in the summer. Never had one come back down. I've done three including a station wagon (two cans). 77 has let me down in this heat. I'm pretty sure they cost the same.
When I did the Corvette I cleaned off all the old material and foam and just used black felt fabric. Not the pool table type but the thicker type and used 3M80 and that was two years ago. I think I spend a total of $13 and the headliner looks great and very close to the original mouse hair padded stuff.
Quick Reply: Thoughts on Headliner Adhesive
