Antenna replacement
Antenna replacement
New to corvettes always wanted one,got a 91 about a month ago and joined here.lots of good info,but can i take out the power antenna and just put in a regular one ? mine not working right.just a standard bolt on one. thanks
I think the power ant was a option. my 1980 has a power ant, my 1985 has non power ant, and the 1994 has a power ant. So I would think you could just get a regular ant and install it.
If you can hear the motor run in the unit when you turn on the radio , it may just need a new replacement mast...Id say 75% of the time this is the problem.. You can pick these up at most Corvette parts sites and even on ebay...Shop for best price....WW
Here's what you need if the motor in the unit still runs....
http://www.parts123.com/parts123/yb....5Z50000050F~~~
Check out these threads they should answer all your antenna questions and give you a very good supplier for cheap OEM antenna parts;
https://www.corvetteforum.com/forums...-way-down.html
https://www.corvetteforum.com/forums...t-trouble.html
