How to shift in reverse on a 1985 C4
Greetings to all, I have a 1985 C4 that is finally back on the road after replacing many parts, it still has a long way to go but it runs! I need to better understand the proper way that I should shift in reverse with my 4+3 manual transmission as I have to fight with it before it goes into reverse.
Thanks for your guidance
Reverse
If you're having problems because it grinds when trying to go into reverse, it might be because the hydraulic clutch has not been bleed properly. It's a pain, but it is possible to bleed them and works well once all the air is out.
Let us know more details and you'll likely get a better answer.
Many times my car just moves forward in the reverse gear until I get it right and then it goes in reverse, I am not just sure how to properly engage the lever on the shift in order to get it into reverse.
On the shift there is a lever than you engage by pressing it up, and then move the shift to the left. Are you supposed to hold it engaged by moving it across and then up?, or just engage it across, release it and then move if up? Not sure if this makes sense.
