Starting the teardown
#61
Dave.
It looks good. And YES...when putting it back together...pacing yourself...even though you will be all 'jacked up' to get it on the road....is wise.
DUB
DUB
#63
Been busy trying to keep up with the falling leaves, car shopping, and family stuff so I havent been able to get a lot done. That said, I did manage to refinish the front bumper braces
And get started cleaning up the F-in overspray off of the lenses. Id like to meet the guy in a dark alley! Scraping the paint out of all of the fine grooves of the reverse lens got me a tad irritated!
#67
The third brake light had always been an issue on my car. The sockets are heat damaged and the metal tabs that hold the bulbs weak. It required me to bend the bulb prongs to "pinch" them to keep them in place, which really didn't help much. So since it's all apart I decided to convert it to 12V LED bulbs. I went with white Alpena LED strips. The set came with two 4 inch strips with 3M adhesive backing. The strips have 6 LEDs each and can be cut in the middle. I cut them which gave me 3 LEDs per light socket. After laying it all out and soldering everything up I used the dremmel to grind down the tabs at each socket. Then stuck them in each socket with the 3M backing. Although the 3M was pretty strong I decided to use electrical tape to secure them further. All I could think was the hot sun softening and loosening the adhesive. The battery pack the set comes with was great for testing connections as I went along. All done and pretty happy with it. These will never get hot enough to melt plastic and I'll likely never have to replace any LEDs. It was a simple inexpensive project as well.
#73
Nice work,
I also have a white one (mine is an 85 though w/o that pesky third brake light which I like about the 85); I had mine repainted about 6 or 7 years ago.
Are you going to keep the side moldings black? I did and sometimes I wonder if I did the right thing although most folks say you don't want to paint those; the paint does not adhere to it or look the same as the fiberglass in a few years. Don't know.
Good thread!
Good thread!
#74
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
#75
Nice work, I also have a white one (mine is an 85 though w/o that pesky third brake light which I like about the 85); I had mine repainted about 6 or 7 years ago. Are you going to keep the side moldings black? I did and sometimes I wonder if I did the right thing although most folks say you don't want to paint those; the paint does not adhere to it or look the same as the fiberglass in a few years. Don't know. Good thread!
#76
but thanks for the compliments and it's good to see a couple of things here; quality body work being performed on a C4 with a quality thread making for a good read.
#77
Got all of the overspray off of the side marker lights and cleaned them up. It took a while. I spent an hour here and there over the last couple weeks but theyre finally done!
#78
Looking good. I did the LED brake light swap a few years ago when I painted my C4. I think it was about $10. Not sure how many of those little bulbs I bought over the years before I did the swap. It was several for sure and around $12 each. The LED still works fine.
