Starting the teardown
Old 09-29-2014, 09:30 PM
Dt86
Dt86's Avatar
Default Starting the teardown
And so begins my cars journey to a new paint job. Hoping to have bumpers,panels,glass,weatherstrip,lights ,mirrors,door handles and everything else removed in 2 weeks. 😆
Wish me luck!
Old 09-29-2014, 09:52 PM
csthews
csthews's Avatar
Good luck.
Old 09-29-2014, 10:09 PM
MRPVette
MRPVette's Avatar
You can do it
Old 09-29-2014, 10:11 PM
1993C4LT1
1993C4LT1's Avatar
Paint doesn't look bad on my screen. Still tho, good luck
Old 09-29-2014, 10:12 PM
peyc2
Support Corvetteforum!
peyc2's Avatar
Going with a color change, or staying with white?
Old 09-29-2014, 11:07 PM
Dt86
Dt86's Avatar
It looks good overall but it's got an older paint job that's starting to peel here and there.
Old 09-29-2014, 11:08 PM
Dt86
Dt86's Avatar
I thought about a color change but decided to stay with the original white.
Old 09-29-2014, 11:34 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Just a little tip. If you remove the belt line mouldings, be careful when tightening during installation.
Use just enough torque to hold the moulding clip. Otherwise the studs will pull too tight and show two dimples for every clip.
Old 09-30-2014, 12:20 AM
Dt86
Dt86's Avatar
Originally Posted by JrRifleCoach
Just a little tip. If you remove the belt line mouldings, be careful when tightening during installation. Use just enough torque to hold the moulding clip. Otherwise the studs will pull too tight and show two dimples for every clip.
Thanks! Keep the tips coming please.
Progress thus far. Time for a beer break
Old 09-30-2014, 04:05 AM
Dt86
Dt86's Avatar
Thats it for tonight. Pleased with the progress so far. Tomorrow Im starting on the doors which should be tons of fun.
Old 09-30-2014, 05:47 AM
ghoastrider1
ghoastrider1's Avatar
big job ahead of you. I plan to follow at some point..checking this post often. best of luck...I havent painted a car since I was 18..46 years ago..
Old 09-30-2014, 07:43 AM
FWC
FWC's Avatar
St. Jude Donor '13, '15-'16,'18-'19-'20-'21-'22-'23-'24
Nice work Dave. If I get back from my road trip in time for reassembly I can give you guys a hand.
Old 09-30-2014, 10:20 AM
1993C4LT1
1993C4LT1's Avatar
Makes sense. Look forward to the progress.
Old 09-30-2014, 10:36 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
If you did that much in one day, you won't need two weeks to prepare the car. The car shows (Overhaulin', Gas Monkay, etc. prep and paint in one day.
Old 09-30-2014, 04:53 PM
Dt86
Dt86's Avatar
Sounds good Frank. It's probably going to be at the paint shop for a while.
Dt86
Dt86's Avatar
They also have 15-20 guys! Lol!
Old 09-30-2014, 08:56 PM
peyc2
peyc2's Avatar
Actually glad to hear you are staying with original color. I'm not a purist but prefer to keep them they way they were born, so to speak.
Good luck with project, I'm about 2 hours away on Long Island, if you need weekend help I could come up. I'll be watching your progress.
To Starting the teardown
Old 09-30-2014, 09:33 PM
Dt86
Dt86's Avatar
Actually glad to hear you are staying with original color. I'm not a purist but prefer to keep them they way they were born, so to speak. Good luck with project, I'm about 2 hours away on Long Island, if you need weekend help I could come up. I'll be watching your progress.
I was close to choosing the dark red but decided that I wanted to keep it the original color. Thanks for the offer!
Old 09-30-2014, 09:39 PM
Dt86
Dt86's Avatar
Everything has gone relatively well except for a few molding nuts. Even though I swabbed some pb blaster on them and let then sit they didnt give and the bolt just spun in the molding. Now its a game of cutting and cooling so the bumper doesnt melt from the heat. Tedious to say the least.
Old 09-30-2014, 10:00 PM
JackDidley
JackDidley's Avatar
I had the same thing when I did mine 5 years ago. Studs were a pain. Even though I cut into the studs, I had enough left to put nuts on to get it together. Good luck with yours.
Quick Reply: Starting the teardown
