crank shaft pulley removal
Old 10-19-2014, 10:48 AM
chatham
chatham's Avatar
Default crank shaft pulley removal
today is the day to replace the opti on my 93. followed this thread which was really well done.
https://www.corvetteforum.com/forums...-pictures.html
got to the point to where I need to remove the crank shaft pulley and the crank is turning so I cant loosen the three bolts holding the pulley on. does anyone have a good method for holding the pulley/crank still so I can loosen the bolts.
Old 10-19-2014, 11:12 AM
Silver96ce
Silver96ce's Avatar
Breaker bar with 5/8 socket on the center crank bolt does it for me.
Old 10-19-2014, 11:19 AM
chatham
chatham's Avatar
thanks for the quick response.
Old 10-20-2014, 06:16 PM
MRPVette
MRPVette's Avatar
What opti did you go with? I just did mine about a month ago it wasn't near as bad as I thought it would be.
Old 10-20-2014, 06:58 PM
chatham
chatham's Avatar
straight forward really. if you're a decent wrench turner it is no problem. I ordered one from SAC City. the price is right and hopefully it will last. I only got 4500 miles from a dynaspark.
To crank shaft pulley removal
Quick Reply: crank shaft pulley removal
