Dash Buttons Sticking
Hello all.....brand new here. I work on a variety of different cars and I am a member of several forums already. Forums are a great place to exchange ideas and get answers to questions. That being said, my first question. Just purchased a 1989 Corvette Coupe and I noticed that a lot of the dash buttons stick really bad, i.e. AC controls etc. If I push really hard they seem to break loose and work fine but are stuck again the next day. I don't know if a previous owner may have been a smoker causing a build up in the buttons or not. Is there a spray that I can use on these buttons to remedy this? Been considering WD40.
Thanks.............
Gary
Thanks.............
Gary
I had a AC control panel (1989) with a mind of it's own. I pulled the panel and used MG Chemicals contact cleaner on it. Sprayed the whole panel with it and gently blew it out to dry several times. I sprayed the front around the buttons and into the back side through a couple small holes. The buttons work and the panel now works correctly.
Gary
There is a sticky under the tech section 4th down from the top. I think it will cover your problem. Dave
Gary
When working on electrical connections on my boats over the years ive had good luck with CRC cleaner. I finish it up with a thin coat of dialectric greese. My 93 will get a sticky button now and then but not bad enough to put it on my list...yet
I'm always looking for an easy way out. Do you think I can spray the front of the buttons while pushing on them or will I have to remove the suspect panel and do it from the rear side?
Gary
Id try it first the CRC quick dry is made to be used on plastics wont hurt them. I used it on my door jam switch and it helped for a while. I replaced drivers side a few weeks ago. Use the red straw and have at at. Good luck
will do....thanks for the help...will check it out this weekend.....
Gary
