Why is the information on my engine spec tag wrong?
This is probably a silly question, but it's been eating at me. The engine spec tag that's on the cup holder lid has the compression ratio wrong. It says:
LT1
350 Cubic Inches
300 Horsepower
330 Torque
9:1 compression ratio.
Obviously the LT1 has a 10.5:1 compression ratio, so what gives? Guessing it has something to do with it being the first year, but I haven't found another one with the wrong info.
LT1
350 Cubic Inches
300 Horsepower
330 Torque
LT1
350 Cubic Inches
300 Horsepower
330 Torque
LT1
350 Cubic Inches
300 Horsepower
330 Torque
Gotcha, that would explain it. Judging by the amount of fade and wear on it, it's probably as old as the car, thus the incorrect info.
My 92 LT1 has this same cover plate, and I've been wondering about that samething. So that plate is not stock?
Received 6,945 Likes
2015 C2 of Year Finalist
This is probably because the C3 actually had one from the factory.
When GM did away with it on the C4, the aftermarket provided one and just about everyone had to have one.
If you want the correct one here is a link to MA, just be sure to check the correct year - http://www.mamotorworks.com/Corvette...plate&Y=&G=&C=
I guess I got lucky since whomever put mine there got it correct:
LT1
350 Cubic Inches
300 Horsepower
330 Torque
LT1
350 Cubic Inches
300 Horsepower
330 Torque
The earlier cars it might not be as difficult to accomplish and maybe the '90+ cars with the dark gray finish could do OK but the "DULSO" finish there's no possible way.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
You're thinking of batch fire vs sequential. The tune port referred to the old L98 style of intake runner IIRC.
Thanks - no argument from me on any of these issues. I do not pretend to be a motor man by any stretch of the imagination. That's why I read, and how I get my self in hot water.....
The original spec sheet for my '93 shows the engine as -
350HO 5.7 MPEI - - - which would make it what???
Also, the original (?) engine spec plate is red with - well see for yourself....
Is this the original plate, I'm seeing others that don't match what is on mine... ?
I guy could finish pulling out what's left of his hair trying to figure out all the semantics in automotive language....
the engine spec plates that I've been viewing are here -
http://www.corvetteguys.com/corvette-engine-id.html
and thanks for the help!
