Questions for a new owner
Hey all i was given, that right GIVEN =), a 1992 Corvette with 54,832 miles. There are some minor issues and some i was able to find in the forums and stickies but some i have not been able to find any information on. i have worked on many cars for many years but always import 4 cylinders. So ive been able to find info about the amp for the passenger side speakers making a squealing noise, and the digital dash flickering on and off until it finally just stayed off. What i need some help on is the drivers side window will go down maybe like 1/2 an inch and then just stop, i plan to take off the door panel and take a look but since its rather cold out if someone had an idea of what exactly to look at/for any saved time int he cold would be appreciated and the other issue it what i think is the overdrive. The car shifts well and smooth until 4th, as soon as it shifts into 4th there a shaking shuttering and if i use drive without overdrive its not there. From some searching it looks like it may be a solenoid or a pressure switch but im not really too sure and have zero experience with automatic trans. Also With what i am assuming is the overdrive issue, would driving without using the overdrive be fine or would you recommend to just not use the car at the moment? Thank you for any information in advance!!
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
Regarding the window, can you raise the window back up after it had been lowered 1/2"? The common problems are bad switches or bad motors. It the motor lowers it a half inch and can raise it again, it doesn't sound like there's a switch or motor issue ...
Congratulations. Christmas came early, huh?
You know that means if you guys break up you gotta give the car back right? Haha.
Max G’s
He said (ex) girlfriend. Sounds to me like the girls dad is either glad to have you gone or he needed a tax deduction and he knew it would cost more to repair the car than the tax incentive he could received to gift it to you. You need a transmission and window regulator.
hmmm maybe ill try that and see since that pretty simple to do, any chance i can just switch the passenger side switch to drivers side to test it out?
Now with that said, one of your first purchases should be a Factory Service Manual. You can find them on ebay and occasionally here for around $50.
Good luck, congrats on the ex-girlfriend- I mean car and welcome to the club.
I actually ended up doing the cleaning to both sides but since the driver's side gets much more use it was giving me more problems. Taking it apart isn't too bad. I used one of those tiny screwdriver sets you get for a couple bucks and was very careful. New drivers side switches are few and far between and pricey if you do find one. Just take your time and be careful with it.
Update: so i pulled the door panel and took a look, i didnt notice anything cause the issue but i was able to get the window to go up and down. The window is going down uneven and will get stuck about half way now ill push it a little towards the front of the car and it will drop the rest. On the way ip it goes about half way pauses then goes 3/4 pauses then goes the rest. The motor seems to be ok cause ot doesnt really struggle or slow down. It does looklike the motor was replaced at somepoint cause it looks like they cut away at the bottom of the door in the shape of the window motor lol.
So I was able to take the digital cluster out and repair the bad connection and my speedometer works great again, i plan on looking at the window guide and possibly trying to diagnose the trans issue tomorrow. Thank you for all the suggestions and information!! I do have another question, the targa top i have is a lexan piece. Was this an upgrade? Would the car have come with the original top and this purcahsed later? My exs father purchased the car new so im not sure if he has it somewhere in storage and forgot about it but im not a huge fan of the lexan top. Thanks again for all the help thus far!!!
