A/C Blower appears to be slowing down on its own.
Thanks in advance to everyone as this is my very first post. I know there are a few posts already on my topic. I have a 1990 with 20k miles on it. It blows very cold and routing functions appear to be working at least in the beginning when I turn it on, however mine too slows down on its own after about 20 minutes or so. Yes, turn it off and come back to it and it is a repeat. Airconditioning programmer issue?
Thanks for your time!
I assume you have the C68 digital HVAC system from your description. Does it have a digital temperature display? If it does, then...
The system automatically adjusts the fan speed based on the difference between your temperature setting and the interior temperature. If the difference is large then the fan will run at a high speed. As the difference becomes smaller the system will lower the fan speed.
